#21 PostAuthor: sprint » Tue May 19, 2015 3:27 pm
Thanks for replies.
I do feel reasonably confident that the valve timing is OK but clearly do not exclude that it may be part of the problem?
Changed the plugs and took it for a ride and there was no change, poor pick up '8' stroking etc.
Stopped to check the plugs and noticed that with the engine running pulling off No 1 plug cap made little difference to the running though you can hear the spark jumping from the cap to the plug from about 1cm away. Tried all the others and it more or less stalled as soon as you pulled the respective caps off.
No 1 exhaust pipe mildly warm that you can hold with your hand all the others too hot to touch.
Changed No 1 and 4 plugs over and it made no difference, so not a plug problem. Got it home and tried another cap, no difference so not a cap problem.
Swapped the coils over, still no difference so not a coil problem?
At tick over speed pulling the cap off No1 does make a difference but at revs above 2K pulling the cap makes no difference?
Indications are that it is not getting any fuel? When you take the plug out it is not wet?
So what am I looking for? When I got the bike it started and ran sweetly and picked up cleanly when the throttle was opened, though I never took it for a ride. All the carbs have been stripped and all the jets, valves etc ultrasonically cleaned as the bike had a known history of running rich. I injected alcohol though all the body orifices followed by air from a foot pump, so I am at a bit of a loss as to why No 1 would not appear to be getting any/sufficient fuel?
Any suggestions as to what I am looking for. I can get to No 1 carb fairly easily with respect to the jets and valve etc and don't want to be pulling them all off again unless I have to.
When I opened the drain screw fuel come out so the valve would not appear to be sticking?
