LOCTITE - "Heat Resistant" for cylinder head?
#1 PostAuthor: Pigford » Mon Apr 27, 2015 12:14 pm
I'm after some hi-temp LOCTITE (or similar) to lock the M10 grub screws in the cylinder head on me Z1000. I've drilled & tapped the air emission passages and want to fix them in place - air tight & secure :!:
Any previous experience on summink that works, gents :?: Ta.
Hinckley
#2 PostAuthor: Hinckley » Mon Apr 27, 2015 12:47 pm
Loctite 641 would be adequate.
#3 PostAuthor: Pigford » Mon Apr 27, 2015 1:05 pm
Hinckley wrote:Loctite 641 would be adequate.
What about temperature - was thinking needs to be above 200 deg C ?
Colour: Yellow
Service temperature range: -55°C - +150°C
Tensile shear strength in N/mm: >6.5
Thixotropy: No
Viscosity in mPa.s: 400 - 800
Fixture time steel: 25 min
Maximum diametrical clearance: 0.1mm
Pack sizes: 10ml, 50ml, 250ml
Coose
#4 PostAuthor: Coose » Mon Apr 27, 2015 1:15 pm
If you never want them to budge again I have a spare small tube of 648 that you can have if you PM me your address. 648 is good to 180DegC which might be enough?
http://www.loctite.co.uk/loctite-4087.htm?nodeid=8802627682305
#5 PostAuthor: Pigford » Mon Apr 27, 2015 1:21 pm
Coose wrote:If you never want them to budge again I have a spare small tube of 648 that you can have if you PM me your address. 648 is good to 180DegC which might be enough?
Thats very kind of you lad :P PM sent :wink:
Richard Q
#6 PostAuthor: Richard Q » Mon Apr 27, 2015 1:21 pm
Loctite 272 will do 200 - 230c
I have an equivalent, around £8.00 for a 50ml to a fellow forumite :)
Be about a week though :??
Richard
Glue Guru
1976 KZ900
#7 PostAuthor: Pigford » Mon Apr 27, 2015 1:24 pm
Richard Q wrote:Loctite 272 will do 200 - 230c
Richard
Glue Guru
Cheers lad - gonna go with Coose's offer as I wanna do it over the bank Hols. many thanx anyhow :wink:
Hinckley
#8 PostAuthor: Hinckley » Mon Apr 27, 2015 1:25 pm
I use it for securing bearings in cylinder heads, gearboxes and axles, also for retaining bushes in power valves and valve guides - never had an issue - have to heat them with a naked flame to remove them.
You can go up to 638 or 648 180°C or 278 +200°C.
#9 PostAuthor: Pigford » Mon Apr 27, 2015 1:26 pm
Hinckley wrote:I use it for securing bearings in cylinder heads, gearboxes and axles, also for retaining bushes in power valves and valve guides - never had an issue - have to heat them with a naked flame to remove them.
Okay, ta. Don't know how hot a cylinder head gets in that area (or any other area TBH) :lol:
Coose
#10 PostAuthor: Coose » Mon Apr 27, 2015 1:32 pm
What goes around hopefully comes around! :)
#11 PostAuthor: Pigford » Wed Apr 29, 2015 6:11 pm
STUFF ARRIVED - MANY THANX - I'LL BE ABLE TO PLUG THE HOLES OVER THE BANK HOLIDAY :up :up :up :up :up :up :up :up :up :up
