Z1000j speedo problems
oorwullie
#1 PostAuthor: oorwullie » Tue Apr 21, 2015 7:57 pm
Hi All, as in title, I changed the front bearings and when I went for a spin to check everything was ok, the speedo was showing half speed, or there abouts. So back home, took the wheel off to make sure I hadn't missed anything, all seemed fine. Back out and it seemed to work for about 2 miles then went weird again. By the time I got home it was hardly reading anything? It's an electronic drive. Any ideas?
Cheers Wullie
nw66
#2 PostAuthor: nw66 » Tue Apr 21, 2015 8:34 pm
Yes change into second gear :roll:
Ducati 1199R Race
Ducati 1198R Race
Suzuki GS/GSXR1216 Turbo Drag
Suzuki Katana 1170 Homa sz
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
The older it gets the faster it was :-))
oorwullie
#3 PostAuthor: oorwullie » Tue Apr 21, 2015 8:40 pm
nw66 wrote:Yes change into second gear :roll:
Aye, thought I was doing something wrong? :shock:
#4 PostAuthor: z1bman » Tue Apr 21, 2015 9:19 pm
is the drive coupling located properly with the one on the hub ?
oorwullie
#5 PostAuthor: oorwullie » Tue Apr 21, 2015 9:34 pm
z1bman wrote:is the drive coupling located properly with the one on the hub ?
Aye, that was the first thing I checked.
#6 PostAuthor: Al » Tue Apr 21, 2015 9:42 pm
If its still clocking up miles accurately on the odometer its not a fault with the speedo drive unit.
The whole set-up is massively and unnecessarily complicated and more than a little frail.
The factory manual has a comprehensive test proceedure for the array and if you follow it you will find the fault.
The speedo head is not re-buildable and has a chip in it which fails.
The drive units on the wheel usually break the wires off just where they enter the casing stub.
The three pin plug in the h/light usually burns out.
oorwullie
#7 PostAuthor: oorwullie » Tue Apr 21, 2015 10:54 pm
Thanks Al, that gives me plenty to work on! Hopefully I'll get time to have a look at it this week. I'll let you know how I get on.
Cheers Wullie
