Front wheel fit
Pinhead
Front wheel fit
#1 PostAuthor: Pinhead » Mon Jan 26, 2015 7:05 pm
Hi all
I cant find a torque setting for the front axle nut
I tried 60 pounds it lock up the axle
I have looked in the clymer manual and it does not say anything about torquing the axle nuts
All is says for the 900 is to reassemble the hub In the reverse order
#2 PostAuthor: z1bman » Mon Jan 26, 2015 7:47 pm
51-65 ftlbs this is for the 27mm nuts
#3 PostAuthor: PAULJAC47 » Mon Jan 26, 2015 8:20 pm
Are you tightening the fork leg bottom clamps first? you should be,something wrong if you are locking the wheel up.Have you got correct spacers in?
Pinhead
#4 PostAuthor: Pinhead » Mon Jan 26, 2015 8:34 pm
Hi again
Just back from the garage it's bloody cold out there
It was me I did not have the speedo in right
It's working now
