Carb choke tube
Carb choke tube
Are you able to buy new ones, a set of z1000 carbs I have has a tube broken off, if they are available who do I need to contact.
Gavin
its not a separate part you will need to remove one from a scrap carb or buy some brass tube. if you have the broken bit remove the jet from the bottom of the tube by taping it out from the inside & press it into the new tube
http://www.ebay.co.uk/itm/Brass-Tube-Pi ... 20f0d2669c
- wheelysteve
Steve
Got home yesterday to find amongst the normal mail that gets put through the letterbox a battered envelope containing the choke tube,
It appears that it had been delivered to the wrong address and reposted.
Thanks a lot , it goes to show what a great groupwe have here
I hope you had a great Xmas and start to the New Year.
Gavin
- wheelysteve
