Split base gasket
kwaka
Split base gasket
#1 PostAuthor: kwaka » Sun Dec 09, 2007 1:57 am
Hi, After installing my base gasket and getting 2 pistons into the barrels i've noticed a split in my base gasket :evil: . It's gone through half the width of the gasket only in line with the centre of one cylinder. What do you reckon, does it need replacing or should i use a bit of gasket glue?
ninjajen900
#2 PostAuthor: ninjajen900 » Sun Dec 09, 2007 3:07 am
:| I would be more pissed if i put it together then it leaked,chances are it wont leak with a bit of red on the split.But to be sure fit a new base,I would. :| good luck
Ed Z1-R
#3 PostAuthor: Ed Z1-R » Sun Dec 09, 2007 1:07 pm
what a pisser :twisted:
you could go the goo goo muck and crossed fingers route and hope it dont go tits up.
I personally would growl a few times stomp about and :fone a new gasket.
saves posssible :bawl later
kwaka
#4 PostAuthor: kwaka » Mon Dec 10, 2007 6:58 am
Thanks fellas, i suppose i better replace it and save the possibility of tears later. Just means i'll have to wait another 2 weeks for shipping and about $50.00 lighter :( .
