Not fast enough ?
Kwackersken
Not fast enough ?
#1 PostAuthor: Kwackersken » Sun Oct 26, 2014 9:39 am
Hi All
Anyone got any idea what speedo I could use to replace this one on my KZ1000J, because it's an import it only goes up to 85mph and I would like one that goes higher but looks similar
As you can see it's an electric speedo with turn light,oil light and neutral light in it, does the UK Model look the same but with higher mph ?
Many thanks
Kenny
[/size]
#2 PostAuthor: PAULJAC47 » Sun Oct 26, 2014 9:56 am
http://www.digital-speedos.co.uk/
Hi Kenny try these, iam fitting some to my latest project or try \John Browse at Wrexam for a uk spec unit..Paul J
#3 PostAuthor: Al » Sun Oct 26, 2014 10:02 am
Is that speedo / odo driven electrically from a unit attached to the wheel / spindle on the LHS via a black sheathed multi-strand wire?
Kwackersken
#4 PostAuthor: Kwackersken » Sun Oct 26, 2014 10:27 am
[quote="zorded"]Is that speedo / odo driven electrically from a unit attached to the wheel / spindle on the LHS via a black sheathed multi-strand wire?
Yes mate that's the one I don't want to change the look of the bike so want the same speedo just showing more MPH
Thanks for the fast replies :D
freddyz1r
#5 PostAuthor: freddyz1r » Sun Oct 26, 2014 10:45 am
Look at the z1100 st, they are very similar clocks :?? If you want I'll take a look at mine later and re post the dimensions etc for you :?:
cheers freddy :D
“It's not me who can't keep a secret. It's the people I tell that can't.â€￾
freddyz1r
PUM 329
Z1parR
#6 PostAuthor: Z1parR » Sun Oct 26, 2014 10:45 am
The speed limit is 70mph Kenny so the speedo that's on should be fine :wink:
0172 . Geoff Parr
#7 PostAuthor: Al » Sun Oct 26, 2014 10:48 am
^ :D
#8 PostAuthor: Al » Sun Oct 26, 2014 10:51 am
In that case its a J1 and a UK speedo / odo (MPH) will be a straight swop if you can find some that work.
There is a slight fly in the ointment in that there is an orange wire in the mix somewhere. I think it is a slightly different set of info lights but cant remember which way round it works!
Not really woken up yet either.
freddyz1r
#9 PostAuthor: freddyz1r » Sun Oct 26, 2014 2:58 pm
Hi kenny, the z1100st speedo is 160mph, it has the same set up as you've got (TURN, OIL, NEUTRAL). And is a total of 98mm diameter.
Cheers freddy :D
freddyz1r
PUM 329
tlc
International Rep
#10 PostAuthor: tlc » Sun Oct 26, 2014 5:05 pm
I have a spare UK speedo Ken.
Asphalt Cowboy
Kwackersken
#11 PostAuthor: Kwackersken » Sun Oct 26, 2014 5:22 pm
tlc wrote:I have a spare UK speedo Ken.
That's great mate :D PM sent
Big Fluff
#12 PostAuthor: Big Fluff » Mon Oct 27, 2014 1:02 pm
If Kenny hasn't taken you up on the offer then please let me know.
Thanks, Will
