Z1A Electrical problems
willjanuk
#1 PostAuthor: willjanuk » Wed Oct 01, 2014 7:25 pm
I have recently restored a Z1A and when I switch the headlight on to main beam the idiot main beam light glows and the headlight seems dim, when I switch to main beam idiot light is bright and main beam is good.
I have checked the wiring in the headlight and found that the main beam terminal has got hot and melted the plastic, but is still useable.
I also have a problem with the bulb failure light in the rev counter in that it it always on.
Anyone have any idea's.
Thanks Will.
1973 Z1 1974 Z1A
willjanuk
#2 PostAuthor: willjanuk » Fri Oct 03, 2014 8:17 pm
Headlight turned out to be wires connected up wrong on the bulb plug as the unit I had red a yellow and a blue wires coming from it which does'nt match the wiring loom and I have disconnected the power to the warning light, so fixed now.
Will.
1973 Z1 1974 Z1A
