bolt wont tighten in clutch cable casing thread gone
keith mayall
#1 PostAuthor: keith mayall » Sat Sep 13, 2014 8:07 am
is there a re thread you can do to the casing or do you get a bigger bolt,,not sure what size the bolts are,the one that wont tighten is important as when I press the clutch it moves and that's only going to get worse,,i bet its common so what do I do lads.
#2 PostAuthor: z1bman » Sat Sep 13, 2014 8:40 am
http://www.ebay.co.uk/itm/M6-X-1-00-Thr ... 1e7e038539
i presume you mean the bolts that hold this cover?
tlc
International Rep
#3 PostAuthor: tlc » Sat Sep 13, 2014 8:41 am
Not sure what you mean.
Clutch stock at the handlebar?
And which model?
Asphalt Cowboy
#4 PostAuthor: chrisu » Sat Sep 13, 2014 9:14 am
z1bman wrote:http://www.ebay.co.uk/itm/M6-X-1-00-Thread-Restore-Tool-Set-Thread-Repair-Size-6mm-x-1-00-Heli-Coil-2741-/130963178809?pt=LH_DefaultDomain_3&hash=item1e7e038539
those work a treat.......................
keith mayall
#5 PostAuthor: keith mayall » Sat Sep 13, 2014 10:29 am
yea that's the one,its one bolt at the bottom front,shredded
keith mayall
#6 PostAuthor: keith mayall » Sat Sep 13, 2014 10:31 am
tlc wrote:Not sure what you mean.
And which model?
the cover which z1bmans put on.stripped bolt.
keith mayall
#7 PostAuthor: keith mayall » Sat Sep 13, 2014 10:35 am
ordered one off ebay cheers again..
