Battery charging issues?
- Regular Poster
Gents, have some concerns with alternator and reg / rectifier as battery died whilst on ride out. Bumped started ok so could get home.
Want to test the charging system but have no figures to go on. Can anyone help with what should the reg / rectifier be putting back to the battery with engine running? And what should be the alternator be putting out on each wire to the reg / rectifier? Thanks
- steve bowdler
Lee, i'm in Portsmouth if you need to borrow any tools. I have the usual digital multimeters and DC current clamps if you need to borrow them. If you need a hand give me a shout and i could come over.
Multimeter on the battery terminals should see no more than 14.5v when the revs are high.....any higher and the reg/recitfier is non functional.
The current clamp is usefull for determining the exact current developed by each alternater winding.....can prove if a winding is open/short circuit.
Three yellows out of alternator 50-60 volts ac between any two,check all combos...as said befote 14.6 volts dc across battery but my Gs only gives 13.5 and is fine....
This picking on me because i have a Gs has to stop Pj,this is getting pretty serious,if you dont behave i will revive the link about you being Peter Stringfellows body double
PAULJAC47 wrote:This picking on me because i have a Gs has to stop Pj,this is getting pretty serious,if you dont behave i will revive the link about you being Peter Stringfellows body double
Don't you start whinging about being victimized too
- Regular Poster
- Regular Poster
My 900A4 BROKE DOWN one day.
It was a dead battery.
Got it home.
Checked out the charging.
It turned out to be a loose multiplug going to the rectifier/regulator unit.
Cleaned it and snapped it together, hey presto and as if by magic it was all good again.
Got it home.
Jimmock.
I hate people I don't like !
I'd like to see this link.
Jimmock.
Users browsing this forum: Bing [Bot] and 13 guests
