Is there anything special about the bolt in the right hand end of the crankshaft which holds in the ignition mechanism on a GPZ1100 ? It measures 62mm long which is a strange length. On a short run out today mine fell out and is now very bent....thankfully it didn't smash the casing though it's had a good go at it.......is it just a standard bolt and I assume it wants thread lock on it ?
Cheers Mike
Crank rotor bolt GPZ11 ?
