Q ~ Sprocket Sizes 17" Wheels & 630 to 530 Chain Conv
wild_zed
#1 PostAuthor: wild_zed » Sat Apr 26, 2014 5:07 pm
For the Z1000J
What are the recommended sprocket sizes, front and rear when doing both
(a) a 17 inch wheel conversion
(b) 630 to 530 chain and sprocket conversion
In my shed
2013 KTM 1190 Adv
2012 MV Agusta Brutale
2011 Ducati Multistrada 1200
2010 KTM990 SMT
1981 Z1000J
1980 H**** CB900F
Blackhat 999
#2 PostAuthor: Blackhat 999 » Sat Apr 26, 2014 5:38 pm
Don"t know, but thats some Exciting bikes in your shed,, :beam
A harley" the most efficient way of turning gasoline into noise, without the by-product of horse-power
#3 PostAuthor: Pigford » Sat Apr 26, 2014 5:39 pm
Just keep the final drive ratio the same - around 2.2:1 :wink:
I'm running a 19 front & 42 rear on me Harris with 17" wheels & 530 chain and it's gearing is pretty good - could even go a smidge higher geared (less tooths on rear) no probs :lol:
#4 PostAuthor: zed1015 » Sat Apr 26, 2014 6:37 pm
You want 1.92 to 1 to equal the original ratio you had with the 18"s.
If you have a chunkier modern swinger then somewhere around 19t front and 38t to 40t rear will help the chain clear the top run.
wild_zed
#5 PostAuthor: wild_zed » Sat Apr 26, 2014 9:03 pm
zed1015 wrote:You want 1.92 to 1 to equal the original ratio you had with the 18"s.
This is the swingarm that I am using, together with ZX9 forks, brakes and rims
In my shed
2013 KTM 1190 Adv
2010 KTM990 SMT
1981 Z1000J
1980 H**** CB900F
weaver
#6 PostAuthor: weaver » Sat Apr 26, 2014 10:09 pm
My elr has 17 inch wheels with zrx swinger,I am now running 17t front and 39 rear which is just about perfect
