Has anyone succesfully painted and plated their carbs black?
If so, how did you do it?
I have a set of BS34s which will be going on my GPZ750, but they're plain alloy and I would ideally like them black, if it isn't too much of a nightmare job.
Painting carbs
Painting carbs
What we got here, is failure to comunicate.
malmojoe
I did some. They were from an ELR so were black, but getting tatty and needed a good clean, so I left them for a day in thinners. Didn't need any blasting and after a good clean with solvent panel wipe, I sprayed them with good quality 2K (PPG Deltron) with satin agent (Lechler Matt3??). Looked spot on.
I examined the carbs before I stripped and dipped them, they were sprayed as an assembly and so that's how I did it.
