I am just about to clean up the parts for the cam chain assembly. i have ordered a new cam chain so i can get the bottom half finished this week. What other parts should i definitely replace while i have the engine in bits?
Thanks in advance.
Cam assembly
Cam assembly
Bike now finished what a joy!
ok im going to have to do this a little at a time so hope you can all bear with me.
Cleaned up the idler assembly and all looks well.
The sprocket moves from side to side by 2mm.
The teeth all look in good shape.
The plastic spacers are hard but in good shape assuming the are plastic and not hardened rubber.
All the metal parts cleaned up nice.
Good to go yes / no?
these are the most common parts that are replaced
https://www.z-power.co.uk/merchantmanag ... cts_id=440
https://www.z-power.co.uk/merchantmanag ... cts_id=443
https://www.z-power.co.uk/merchantmanag ... cts_id=450
https://www.z-power.co.uk/merchantmanag ... cts_id=438
https://www.z-power.co.uk/merchantmanag ... cts_id=839
https://www.z-power.co.uk/merchantmanag ... cts_id=396
