Clutch basket
mark d
Clutch basket
#1 PostAuthor: mark d » Tue Feb 11, 2014 6:45 pm
Me z1000a1 has started to rattle sounds like from clutch / gearbox area the motors been stripped and all bearings are ok but there is play in the clutch basket which none of the main suppliers can get any more , has any one had a bearing rattle from this before ? I've had the bike for 34 years and its never been apart until now
4 pipe a1, st , gpz Rx 1000 otr , gpz Rx 1000 restoring , Rx bitza in boxes
#2 PostAuthor: Ginger Bear » Tue Feb 11, 2014 6:57 pm
Contact Gez635 or Al Marshal, both on here & can be contacted via PM.
I think one if not both of them can replace the springs in your clutch basket.
# 104
mark d
#3 PostAuthor: mark d » Tue Feb 11, 2014 7:14 pm
Cheers, I've spoken to ray debben today and he was going to look at the clutch basket to see if it was not to far gone to re spring it . When you find a bearing gone its simple but not finding one gone is a head ache ,I will of course be replacing them all .
DogsbolloxofZ1B
#4 PostAuthor: DogsbolloxofZ1B » Tue Feb 11, 2014 9:46 pm
mark d wrote:Cheers, I've spoken to ray debben today and he was going to look at the clutch basket to see if it was not to far gone to re spring it . When you find a bearing gone its simple but not finding one gone is a head ache ,I will of course be replacing them all .
Mark,
Have you removed the clutch plates and checked that the caged needle bearing and the inner bush are a good fit? If you can detect a lot of movement then it's probably not worth spending money on replacing springs until you've replaced the bearing or sleeve or both.
Mike
mark d
#5 PostAuthor: mark d » Sat Feb 15, 2014 8:25 am
To be on the safe side I will have every bearing changed whilst it's apart and fit a new cam chain etc , I don't mind spending the money on my bike as it's the first problem I've had in our 34 years together :D
#6 PostAuthor: Pigford » Sat Feb 15, 2014 8:43 am
Also - be well worth checking the alternator rotor - they do work loose over the years :shock:
