what rings
zman
what rings
#1 PostAuthor: zman » Fri Jan 10, 2014 1:35 pm
my 900 has been bored out to 1015 and has standard pistons.
What replacement rings would i need?
thanks
keep thoses wheels turning
#2 PostAuthor: chrisu » Fri Jan 10, 2014 5:50 pm
i presume you mean kawasaki pistons ?
Someone who know better than me will be along shortly but i'd play safe and fit kawasaki ones. Not tested for example wiseco rings in std pistons.
#3 PostAuthor: z1bman » Fri Jan 10, 2014 6:08 pm
jimmock
Re: what rings
#4 PostAuthor: jimmock » Fri Jan 10, 2014 6:15 pm
zman wrote:my 900 has been bored out to 1015 and has standard pistons.
thanks
I would have thought standard pistons in a 1015 would be rather "slack" ??? :doh
:fish
Jimmock. :wnkr
I hate people I don't like !
Re: what rings
#5 PostAuthor: ADRIAN H » Fri Jan 10, 2014 8:43 pm
thanks
Jimmock :bop
Did make me laugh though. :lol: :lol: :lol:
jphaynes669
#6 PostAuthor: jphaynes669 » Fri Jan 10, 2014 8:56 pm
Dave,, after all this time and turmoil , did you have broken rings all along? :cry:
Jeff.H
zman
#7 PostAuthor: zman » Sat Jan 11, 2014 1:01 pm
not sure if its rings as head is being checked out.just wanted the info just incase.
But engine firm said all the evidence pointed to the head but can't find a fault,but are doing a check for cracks.but if not it must be in the bottom end. And as boars are good it must be rings
jimmock
Re: ..
#8 PostAuthor: jimmock » Sat Jan 11, 2014 1:11 pm
zman wrote:not sure if its rings as head is being checked out.just wanted the info just incase.
zman,
What actually is the problem?
Rings, bores, heads and now bottom end????
Jimmock. :wnkr
z1000puddin
#9 PostAuthor: z1000puddin » Sat Jan 11, 2014 3:14 pm
zman - Was the engine......
1) Smoking ?
2) loss of power ?
3) Unusual noise ?
4) compression values down?
With the symptoms - it may be easier to analyse for the solution.
Stu
Zed til Dead
#10 PostAuthor: zed1015 » Sat Jan 11, 2014 5:58 pm
Piston rings.
Here you go.
IMD rings. These are as good as genuine.
Full set STD £99.99
http://www.ebay.co.uk/itm/VINTAGE-KAWAS ... 2328854e12
