Clutch problems
Clutch problems
I have just fitted new friction clutch plates to my Z1000A1, as it was slipping at high revs. When fully engaged the clutch is now working great, but it is juddering/binding when trying to ride the clutch to pull away in first.
Any thoughts ?
Chris
Any thoughts ?
Chris
neilbarrett
wilsonsjw11
Sounds like drag because the clutch isn't fully disengaging due to the added thickness of the new plates.
You need to slacken off the clutch cable at the bars and take up the initial slack on the pushrod via the adjuster in the sprocket cover.
You should also soak the new plates in engine oil overnight before fitting.
Fitting them dry can cause excess wear of the frictions and overheating of the plain plates causing them to warp which will cause clutch drag also.
Also check plates are free to slide in the basket,sometimes they can be a little stiff and req dressing with a smooth file...you are not using car oil by any chance?just a thought it might be that causing initial slip...
- z1000puddin
But it wasn't doing this before I replaced the friction plates, so I would be surprised if a sping had broken.
I didn't soak the plates in oil before fitting them. Could I have now damaged something by not doing this or do you think that if I take them out, soak them as you say then refit the problem will be solved, with no detrimental affects ?
You might get away with it if you haven't been far.
Give the frictions a very light scrub on a flat surface (concrete paving slabs are good for this or fine wet and dry on a mirror etc ) to remove any glaze then soak overnight.
Check the plain plates for blueing and warping.
Re-fit and re-adjust any slack at the pushrod before moving on the cable and you should be ok.
There was no problem with operation when the clutch was depressed during normal operation, just in first when trying to pull away. I did do about 20miles, but as I say the only problems were at the occasional junction.
I will do as you say and hope for the best !!!
There was no mention of soaking new plates in the haynes manual !!!
Thanks for your advice.
- paul doran
snotie1965
evans wrote:There was no problem with operation when the clutch was depressed during normal operation, just in first when trying to pull away. I did do about 20miles, but as I say the only problems were at the occasional junction.
Have you got anywhere with your crutch issues ? (update)
