so the H has decided to throw a wobbly again !!
It runs then it doesn't then it runs then it doesn't !
Anyway after stripping everything down rewiring the injection loom changing everything pump, regulator, relay cleaning the injectors you name it I've done it, to no avail. so on day 4 I for got to attach the temp sensor wire and it ran !! attach it, it doesn't replaced the sensor with a good one same thing doesn't like it
it runs crisp probably better than ever with it not connected so is it the brain ? I would have thought it wouldn't run with it connected
also why would it be intermittent it ran last week for a whole day with it connected all of the loom has been replaced so no faulty joints etc
Anybody got any ideas ?
z 1000h again
z 1000h again
Gravity is a myth ...... The earth sucks
1000H
yeah I know Ollie, logic says it shouldn't run without a signal,
took it for a ride today wouldn't pull missing like a pig, further investigation needed would prefer a H over a MKII but the carbs are on the bench !!
,mmmmmm errrrrr ..lol ,they are strange beasts these H's ,mine wouldn't run without it connected.So ive no idea why yours is doing that
