swapping carbs, CSR to ST
stevie g
#1 PostAuthor: stevie g » Tue Aug 27, 2013 8:04 pm
Hi Guys, I was thinking about fitting 1000 ST carbs to my CSR1000. does anyone know if i'm gonna encounter any probs ? i have the rubber manifolds for both so that ain't a problem. Why did they fit these on the ST anyway ? Reason I'm thinking about doing it is, think CSR carbs are in need of a total refurb, thanks to all replies in advance, $tevie :fou
stephen g mackay
#2 PostAuthor: paul doran » Wed Aug 28, 2013 9:53 am
carbs will fit okay
does Your ST carbs have the pump fitted to the bottom of number two carb
if so this may cause the engine to run a little rich
stevie g
#3 PostAuthor: stevie g » Wed Aug 28, 2013 10:24 am
paul doran wrote:carbs will fit okay
Hi Paul, OK thanks for that. No I ain't seeing any pump on No2. $
stephen g mackay
#4 PostAuthor: paul doran » Wed Aug 28, 2013 12:48 pm
they should run fine so
stevie g
#5 PostAuthor: stevie g » Wed Aug 28, 2013 3:57 pm
paul doran wrote:they should run fine so
Thanks mate, $
stephen g mackay
