Hi All, i am just putting back together an A4 Z900, i have 2 sets of carbs but not sure which is correct. 1st set has 2 feeds for fuel and what seems to be a link pipe between the carbs, flexible fuel pipe. This pipe sits between 1&2 and 3&4. Cable link sits at top of carbs. Throttle stop above carbs.
The other set of carbs have 1 feed for fuel and what seem to be 2 breather pipes. Cable link differs from 1st set with 1 cable link further down between the carbs. Throttle stop is underneath.
I think both are 26mm carbs and look identical apart from bits above.
Z900 A4 Carbs
- Surfdeneige
- Surfdeneige
