The one that flows slow is feeding a pair of carbs that are running rich.So was thinking this may be the problem
fuel tap
fuel tap
I have a fuel tap with two outlets.One out let flows about twice as fast as the other.I assume that they should flow the same
keep thoses wheels turning
Re: ---
zman wrote:My thought was that when running this could creat a low fuel leal.so could this then creat bad atomisation which may then creat a rich mixture
Hmmm - if float level is LOW - then it should be running lean
Re: ---
Low fuel level would give you a weak mixture.
