Rear Axel Nut position
andrew Z1B
#1 PostAuthor: andrew Z1B » Fri Mar 15, 2013 6:12 pm
I know this subject has been raised before but after searching i am buggered if i can find it :??
I am sure the post said the nut should be on the brake side. This is also confirmed looking through the Dave Marsdens book. However, looking at the kawasaki parts pages and Haynes comic the nut is on the sproket side.
What is the correct end and does it make any difference?
Andrew
DogsbolloxofZ1B
#2 PostAuthor: DogsbolloxofZ1B » Fri Mar 15, 2013 6:29 pm
Nut goes on the brake hub side as it left the factory.
Mike
Jay1969
Re: Rear Axel Nut position
#3 PostAuthor: Jay1969 » Fri Mar 15, 2013 6:52 pm
andrew Z1B wrote:I know this subject has been raised before but after searching i am buggered if i can find it :??
Andrew
Just to confirm for you, this is a photo detail from my genuine 1972 Kawasaki Shop Manual[img][img]http://i265.photobucket.com/albums/ii238/silvermachine38/GenuineShopManual1972_Z1sprocketpage_Jay1969_zpsace63fae.jpg[/img][/img]
floydsz1
#4 PostAuthor: floydsz1 » Fri Mar 15, 2013 7:18 pm
If the nuts on the sprocket side the end of the spindle catches on the standard silencers.
Z1b, z900 A4, zxr750 m2, zrx1200
Z1000 (2003) lawson thingy,
Z1000 (2004) z1b lookalike ,
Z1000j lawson race bike,
Gsxr750H.
andrew Z1B
#5 PostAuthor: andrew Z1B » Fri Mar 15, 2013 7:30 pm
This is the way I have it, good to know that is correct.
Thanks Guys, much appreciated.
