One problem solved and comes another one
maak
#1 PostAuthor: maak » Tue Mar 12, 2013 7:58 pm
:lol: Today I cycled around 12 miles to fix my rear brake on the kz700 as it didn't work when got the bike.Started with usual check,brake fluid,pads..all fine.Thought I will bleed it..done it and rear brake fine.Took off speedo to see what's in and under,took off seat and tail piece to see how would it look like without,then after a few pics put everithing back on bike except speedo as is fecked..Start the bike to test rear brake and no lights :roll: Not even brake light.Indicators all work.Anyway..we went out for a quick spin with my mate as he manged to start his WR250 and said for a few seconds my light worked.
What did I do wrong?Why is not working?Why does it always happens with me???? :splat :splat :splat
gray
#2 PostAuthor: gray » Tue Mar 12, 2013 8:14 pm
loose connection pulled apart when you replaced the seat?
Fuse?
does it have self cancelling indicators/daytime running lights? So conceivably not having the speedo fitted will disrupt the circuits
gray
maak
#3 PostAuthor: maak » Tue Mar 12, 2013 10:54 pm
Daytime running lights,yes as it's a US import and yes speedo is off..Fuses were fine..So if I put the speedo back all should be fine?! :shock:
gray
#4 PostAuthor: gray » Wed Mar 13, 2013 8:18 pm
doesn't cost you anything to try it
gray
maak
#5 PostAuthor: maak » Wed Mar 13, 2013 10:49 pm
gray wrote:doesn't cost you anything to try it
12 miles cycling...again... :dead :lol: :lol:
