Exhaust collars
ricky13
Exhaust collars
#1 PostAuthor: ricky13 » Tue Mar 05, 2013 4:57 am
Hi
I am confused
Which way do the 2 half collars fit on to exhaust headers
They seem to go only one way but when I fitted them and tightened them up the exhaust was still blowing at the head outlets
I have fitted new seals as well
Many thanks again
A pic would be good
Ricky
#2 PostAuthor: z1bman » Tue Mar 05, 2013 5:30 am
the lip on the collar faces the exhaust clamp
ricky13
Collar
#3 PostAuthor: ricky13 » Tue Mar 05, 2013 5:44 am
So does collars fit inside the clamp
#4 PostAuthor: z1bman » Tue Mar 05, 2013 5:53 am
if you look at the clamp's there is a recess where the lip on the collars fit
ricky13
Collars
#5 PostAuthor: ricky13 » Tue Mar 05, 2013 5:57 am
Ye
Makes sense that is how I had them I must not have tightened the collars up enough
Keefleaf
#6 PostAuthor: Keefleaf » Tue Mar 05, 2013 9:33 am
Exhaust gaskets?
ricky13
Collets
#7 PostAuthor: ricky13 » Tue Mar 05, 2013 10:04 am
Hi
New copper ring gaskets fitted are there any others[/i]
#8 PostAuthor: z1bman » Tue Mar 05, 2013 10:18 am
are the exhaust clamps bottoming out against the cylinder head? if they are you will need 2 exhaust gaskets in each port. slide the clamps away from the head + make sure the exhaust pipe is sitting square in the exhaust port
Garn 1
#9 PostAuthor: Garn 1 » Tue Mar 05, 2013 10:34 am
Ricky, if the half collars are new (repro's), I have noticed they sometimes have to be ground a little on the edges, to make them a nice fit in the exhaust flange recess.
ricky13
Hurrah
#10 PostAuthor: ricky13 » Tue Mar 05, 2013 1:27 pm
Guys
Many thanks they are now fitted nice and snug
Anyway to totally honest I had them round the wrong way
Dohh
Please feel free to laugh loudly
Ta
Ricky
andrew Z1B
#11 PostAuthor: andrew Z1B » Fri Mar 15, 2013 8:53 am
Hope you don't mind me jumping in on this thread.
I am just about to refit my exhausts but did not pay attention when I took the pipes off as I just assumed it would be like my ZXR & KH.......then the shells fell out...
I have looked on the parts diagram and it shows the shells inserted first then the gasket and the pipe is clamped by the finned bracket. Is this correct as I was thinking the gasket would go in first like my other babies. But the more I think about it the parts diagram does make sense................ :confu
#12 PostAuthor: ADRIAN H » Fri Mar 15, 2013 9:10 am
Gaskets first, then exhaust downpipes, then the half circle collars, then the clamps. regards Adrian.
andrew Z1B
#13 PostAuthor: andrew Z1B » Fri Mar 15, 2013 5:51 pm
thanks adrian, thats two drinks i owe you!
