The plan is to build a fairly standard looking zed twinshock with more up to date 17†wheels, forks and brakes, may be along the lines of piggy’s
It came as a job lot in box’s [in complete] needing a total nut and bolt rebuild, it came with a zxr750 front and rear wheels [the rear is180mm] forks yokes and brakes, it ’s also has a zephyr 1100 swing arm which seems to be possibly two wide to suit the frame and suspension set up
I’ve looked at various projects where up side down forks have been used and extended to give ride height to compensate for smaller wheels, but I don’t think that would an option with the zxr forks.
I’ve looked at some gsxr 750 forks on flea bay but not sure if this would be a better Option
Your thoughts greatly appreciated regards Alan
