Tacho Seal
redkz
Tacho Seal
#1 PostAuthor: redkz » Fri Aug 17, 2007 2:33 pm
How do I change the Tacho seal on my KZ1000A1?
Is it simply a matter of hooking out the old one or do I have to remove the bracket assembly or remove the rocker cover?
#2 PostAuthor: Rich » Fri Aug 17, 2007 4:27 pm
Take the drive off the engine - no need to remove the cam cover - prise old seal out press new one in. Put a new "o" ring in while it is out and redo the seal to the cable outer.
redkz
#3 PostAuthor: redkz » Fri Aug 17, 2007 4:39 pm
Thanks for that Rich
