o-ring carbs
alinus65
o-ring carbs
#1 PostAuthor: alinus65 » Tue Feb 05, 2013 9:56 pm
hi,
I am dismantling one by one the carbs of my Z1b.
While reassembling one carb I found one black o-ring which now I don't know where I should fit it.
Apparently the are two of those o-ring out of 4 carbs...(not sure about that).
Here the photo.
help me please.
#2 PostAuthor: z1bman » Tue Feb 05, 2013 10:00 pm
what are the dimensions of the o ring? the only o rings that i know of in the carb are the ones fitted to the drain screw/ nut on the bottom of the float bowl
z1000puddin
#3 PostAuthor: z1000puddin » Tue Feb 05, 2013 10:16 pm
Zed til Dead
#4 PostAuthor: z1bman » Tue Feb 05, 2013 10:23 pm
z1000puddin wrote:Might find it here
http://www.cmsnl.com/kawasaki-z1-b-1975 ... ml#results
only o ring shown on the diagram in no 35 float bowl drain nut or screw
alinus65
#5 PostAuthor: alinus65 » Wed Feb 06, 2013 10:15 am
z1bman wrote:what are the dimensions of the o ring? the only o rings that i know of in the carb are the ones fitted to the drain screw/ nut on the bottom of the float bowl
it is 10 mm diameter and approx 1.4 mm thickness.
strange thing is that I found only two o-rings out of 4 carburettors I have opened...
hal
#6 PostAuthor: hal » Wed Feb 06, 2013 11:00 am
I think there are o rings that size under where the choke mechanism screws into the carb body
Steve Cooke
#7 PostAuthor: Steve Cooke » Wed Feb 06, 2013 7:35 pm
Some times people fit an o-ring to the joining tee piece to stop leaking, so if it's not from the carb itself it may from there.
Z1parR
#8 PostAuthor: Z1parR » Wed Feb 06, 2013 7:37 pm
Just taken some measurements from a set of VM28s chokes and the O ring is 11.5mm OD x 1.5mm cross section .
0172 . Geoff Parr
