have you got a zrx and a zed ?
i am trying to find out the differance in size between the 2 (vertical widthways and length front to back) if anyone can help ive been offered a motor and electrics and am wondering if it will go in my Harris.
- harrythemagnum
I've tried a ZZR engine in my Harris frame, the mounts bascly line up but the front mount on the Harris, like the Zed is off-set, but your biiggest problem will be the front down tubes, the exhust ports exit right onto frame, you will have to cut and shut the tubes, which I couldnt do.
What a wonderful philosophy you have,
