Hello gents does anyone on here know if its possible to change the oil level sight glass on a gpz1100 clutch casing or does the entire casing have to be replaced.many thanks in advance
John
sight glass
sight glass
got the casing off and you cant push it out because of the way the casing is cast is it ok to break the glass and prise it out from the front without damaging anything.
thanks john
thanks john
