not a z but need advice
The battery on my xt500 is not charging, only getting 1,5v at the battery with engine running. I assume the reg and rect are ok as they are recently fitted within the last year so I think the lighting coil is at fault. If I put a meter on the yellow wire I get continuity to ground, same reading with the 4 wires in the plug. I need to know before trying to ' the flywheel off and sending it for rewinding. Useless with electrics so need help please
