throttle position sensor
rodge70
#1 PostAuthor: rodge70 » Thu Aug 02, 2012 1:12 pm
does anyone have the tool/gizmo to reset throttle position sensor on gpz1100a as the screws fell out on the way home last weekend,sort of put it back together using what screw markings i could see and wondering if it's sort of near enough or should it be set properly,thanks
#2 PostAuthor: z1bman » Thu Aug 02, 2012 7:08 pm
when adjusted correctly you should hear a clicking noise similar to a micro switch when the throttle is just beginning to open. i did have the genuine Kawasaki tool but sold it on e bay last year
rodge70
#3 PostAuthor: rodge70 » Thu Aug 02, 2012 7:34 pm
thanks for info,is that with ign on or engine running?
#4 PostAuthor: z1bman » Thu Aug 02, 2012 7:41 pm
with ignition on
