I am making a list of to do things for my Rickman, i think the priority is the carbs, i went into my garage the other morning and it stank of petrol,
I think it must be the float valves or float height as there is a slight weeping on the overflow pipes, it is not a drip just  slightly moist when you put your finger on the bottom of the pipes, so what i am doing for now is turning off the petrol taps just before i get into my road so that the bowls are almost empty and it wont leak overnight, my worries are that extra petrol will get in the oil and dilute it , and it is going to run rich
My questions to you guys is where is the best place to buy my carb bits ?
Is this a common problem?
Is there anything else i should be doing to them?
Thanks in advance for your replies
Z1R carb Help Needed
- The Zedster
 - Regular Poster
Re: Z1R carb Help Needed
The Zedster wrote: where is the best place to buy my carb bits ?
NRP - http://www.nrp-carbs.co.uk/ is a good starting point
Sorry cant help on your other questions (im a numpty on anything technical
Wots up DOHC
The Zedster wrote:I am making a list of to do things for my Rickman, i think the priority is the carbs, i went into my garage the other morning and it stank of petrol,
take it was u that got that off ebay then
the carbs are 34 yrs old now so time for a full rebuild u need a full rebuild kit from z- power or cheap ones off ebay. pays ya dosh yor choice
fully strip them then
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
Z1OC # 886
carb cleaning
treat your self to one of these superb kits
Z1OC # 886
Z1OC # 886
I have one carb on my Z1R which has a habit of taking a leak, sometimes it does sometimes it don't, Keith Z1R had the problem to stripped his carbs down and rebuilt, still did it, not the only one to have it either, could it be another problem with ethanol fuel, which is only going to get worse, bloody EU., like the cleaner kit Neil!
									CB125  GT380  CB750F1  Z1R  GPZ 750 Turbo  Z1R
						z1r
DavidZ1R wrote:I have one carb on my Z1R which has a habit of taking a leak, sometimes it does sometimes it don't, Keith Z1R had the problem to stripped his carbs down and rebuilt, still did it, not the only one to have it either, could it be another problem with ethanol fuel, which is only going to get worse, bloody EU., like the cleaner kit Neil!
as your post before david stiff tap is defo the ethanol never had prob's in the 70's with any taps had fizzy's yams suzks' etc with 4 star
Z1OC # 886
Z1OC # 886
