mikuni vm26/28 series mixture metering screws
lta01
#1 PostAuthor: lta01 » Mon Jul 23, 2012 8:00 pm
These are a very fine point brass screw found under the front of the float bowl on some models. I'm overhauling a set of carbs for a fellow vjmc member and have found 3 of the 4 screws with the tips broken off.
I've managed to remove the broken tips from the body, but need 3 new screws. Does anyone either know where they can be bought, or have a set for sale ....please
thanks
Loz
He who dies with the most toys wins .
sweptail
#2 PostAuthor: sweptail » Mon Jul 23, 2012 9:46 pm
Loz
Do u mean the air screws? If so u can have my old ones. I will be in southport every day this week, so i can even deliver for u too. :)
tommy
#3 PostAuthor: zed1015 » Mon Jul 23, 2012 10:25 pm
Try ALLENS PERFORMANCE for the fuel mixture screws.
#4 PostAuthor: Rich » Tue Jul 24, 2012 5:46 pm
Have a look on Z1 Enterprises web site
Z1parR
#5 PostAuthor: Z1parR » Tue Jul 24, 2012 8:02 pm
Will this new set do Loz ?
0172 . Geoff Parr
DogsbolloxofZ1B
#6 PostAuthor: DogsbolloxofZ1B » Wed Jul 25, 2012 4:52 pm
Z1parR wrote:Will this new set do Loz ?
Z1Par,
If Loz doesn't want them I'll take them off your hands, just let me know.
Cheers, Mike
lta01
#7 PostAuthor: lta01 » Wed Jul 25, 2012 5:15 pm
sorry, they're gone
Jeff Saunders
Fuel Screws - Pilot Circuit
#8 PostAuthor: Jeff Saunders » Thu Jul 26, 2012 9:30 pm
http://www.z1enterprises.com/ItemDetails.aspx?item=SIK-1157SK
We had a bunch of these made for us in Japan.
lta01
#9 PostAuthor: lta01 » Fri Jul 27, 2012 7:35 pm
thanks Jeff, i did try to look on your site, but failed. Seems you have to create an account or something ?
Jeff Saunders
#10 PostAuthor: Jeff Saunders » Sat Jul 28, 2012 6:10 pm
To search, no account is needed. The current version of the web site requires you setup an account when you are adding parts to the shopping cart. While it takes a minute to setup the account, once it's established, it's going to be there for you each time you visit.
In a few weeks this limitation will go away.
