Hi all
Thought I give the old girl an oil change today, Drained old oil put new filter in
refilled with new oil. problem is it only took 2 liters of oil and is above site glass. check old oil and measures about the same amount! What did I do Wrong never happened to me before.
oil change
Oil level always drops after you have initially ran the engine as the filter sucks up some of it. I did my yearly oil and filter change in June . it appears Castrol GTX is no longer any good as its now Semi Synthetic and causes the clutch to slip at about 4k rpm
.So I changed it for Rock oil part synthetic ( No idea what the difference is ). But after doing 25 miles the clutch no longer slips
well hopefully.
colinKZ900B1
