Any tips or ways to unblock them??
Blocked pilot Jets
Blocked pilot Jets
Got the carbs off my Z1r and two of the pilot jets are blocked
Malc87, if they are gummed up solid, like I have seen some, I don't think ultrasonic cleaning will clear them. Maybe thinners will dissolve the vanishes, I haven't tried that.
I had some success with soaking pilot jets for about 4 hours in a Yamaha product. Yamaha make two types of solution, one for putting in petrol and one for soaking and cleaning. The one I used was the latter, it had written on the plastic container "You will die if you breath the fumes".... I'm still alive and it did the job of dissolving the gum.
Regardz
Regardz
malc87 wrote:Ginger Bear wrote:Probably gummed up Malc. A good soak in some thinners will help before 120psi goes through 'em.
I will get them soaking steve
Malc,
Sounds like a FEW of my ex burds!!!!!!!
Jimmock.
I hate people I don't like !
Re: Blocked pilot Jets
malc87 wrote:Got the carbs off my Z1r and two of the pilot jets are blocked![]()
Malc,
The best way to clean them is,....
Drill them out with a 1/8 th drill!!
Glad to be of help AGAIN.
Jimmock.
jimmock wrote:malc87 wrote:Got the carbs off my Z1r and two of the pilot jets are blocked![]()
Malc,
Should the drill be set on "Hammer"??
