Can anyone advise on changing from a Regulator to a Regulator / Rectifier.
Following a problem starting the bike, i charged the battery up and found the charging voltage went from 13.7 to over 17 volts at about 4,000 rpm - Regulator problem.
Z Power advised the regulator is no longer available, and i now have a nice shiny Regulator / Rectifier with the same Green Plug, a black earth and a white wire, which i think should be connected to the white wire that was connected to the standard Rectifier unit ???
Question is, what do i do with the White plug, now that its function has been replaced with a combined unit? Is it OK to just remove the old rectifier and leave the white plug blank?
Any advice would be appreciated.
Jim
Regulator v Regulator / Rectifier
- KwackerNut
Far away across the field,
The tolling of the iron bell,
Calls the faithful to their knees
To hear the softly spoken magic spells.
- z1000puddin
- KwackerNut
KwackerNut wrote:Thanks
I will take that as, Yes, its OK to just remove and forget.
Great service we get in this club, 7 minutes for the answer, top stuff.
Jim
My wife says I'm much quicker than 7 minutes!!!
Jimmock.
Jimmock.
I hate people I don't like !
- KwackerNut
Cheers Garn
Have done a few trips on her now and she seems to be OK.
Will make sure the white plug is blanked, as i have removed the single rectifier unit.
Voltage across the battery goes from 13.5 to about 14.7 at 3,500 rpm and above, which I thought was a bit high. Any ideas, or is this standard?
Jim
Jim
- KwackerNut
Users browsing this forum: No registered users and 95 guests
