Hi all, from what I can gather the carbs I have fitted to my zed bitsa are 28mm z1b carbs with the drain plug on the side of the float bowls. I cant find a parts diagram of this particular type only one with the drain plug on the bottom of the float bowl, dont know if it matters. Problem I have is the throttle pulley has knackered holes where the cables attach and I cant find its part number to try and source a replacement. Any ideas as there seem to be loads.
Cheers.
Carb Part part number
Gee Carpy, I'm not sure if these butterfly shaped throttle pulleys are the same for both Z1 thru to Z1B. I know they are different in the pilot jets & float bowl, and spring configuration, otherwise they are the same.
Anyways, I think you will have trouble getting one.
I think they are just pressed sheet metal on both.
How about repair (silver-solder) old one and re-zinc?
there are 4 different part numbers it all depends on your frame no as to what pulley wheel is fitted but if you say you bike is a bitsa you will find it very difficult to find a replacement i have seen them for sale in the us. i am sure someone who is into fabricating should be able to weld or braze a new piece of material over the worn part of the pulley
- steve bowdler
