Timing Question
DavidZ1R
Timing Question
#1 PostAuthor: DavidZ1R » Mon Apr 23, 2012 4:21 pm
Trying to set my points with a circuit tester to do static timing, in the book it says to conect the meter to the spring and earth, using audible tone to measure when the points just open at top dead mark, my prob is the meter buzzes all the time, that is when points are open or closed, it only works when I disconnect the lead to the coil, is it suppose to do that or do I have a short, the motor starts and runs mostly ok? its on a 250 twin by the way!
#2 PostAuthor: PAULJAC47 » Mon Apr 23, 2012 5:21 pm
Hi David are you doing this with the battery connected? if so disconnect it and try again, sounds like meter is picking up voltage when you have it on the ohms scale..Cheers Paul J
#3 PostAuthor: z1bman » Mon Apr 23, 2012 5:25 pm
when the meter is in the buzzer position it relies on the internal battery for its own voltage. so do the test with the ignition of
DavidZ1R
#4 PostAuthor: DavidZ1R » Mon Apr 23, 2012 7:48 pm
Cheers guys, the ignition was off but the battery was connected, that makes sense, im not a real mechanic :oops: :lol:
Big Fluff
#5 PostAuthor: Big Fluff » Tue Apr 24, 2012 8:53 am
Using a thin cigarette rolling paper works just as well :wink:
Z903
#6 PostAuthor: Z903 » Tue Apr 24, 2012 11:41 am
Once upon a time you could use a transistor radio sitting beside you, and you'd listen for the "crack" when the points open.
Big Fluff
#7 PostAuthor: Big Fluff » Tue Apr 24, 2012 6:30 pm
Z903 wrote:Once upon a time you could use a transistor radio sitting beside you, and you'd listen for the "crack" when the points open.
Eeee, them were t' days :gom
