A couple of times now my bike has bogged down whilst trying to
make a quick getaway from a standstill, this afternoon was the
worst cos it did it on a busy roundabout with a car looming down
on me.
Bike is a GPZ1100 running CVs and seperate K&Ns, do you think
it`s this carb setup that is causing this problem or should I be
looking else where?
Any advice most welcomed or I`ll have to find a route to work
without roundabouts.
Allan
Scary moment
- big green bus
I haven`t had this bjke long, it has done it before but I think
It was more noticable this time cos it happened in busy traffic.
Went looking for it today, if I use reasonable amounts of throttle
or have at least 3500rpm dialled in you`d never know there`s a
problem if the throttle is cracked open quick at lower revs then
it bogs down and gets spluttery release the throttle a bit and it
starts to pick up cleanly.
