fuel injected G/ H Gremlin - Any experts out there ????
				linus918
I've got a 1980 G Fuel injected model ( unlucky for me !!!) that has been over a year in the rebuilding.  I know the ecu, air flow meters - main components of fuel injection are good, but I have the bike only running on 1,2,&3 pots.
The bike was recently set up and was purring like a kitten, until went for a ride. Then within 10 miles it went down to 3 pots. The 4th pot has spark, has pulse from injector. I have swapped coils, swapped injectors but still no life and that cylinder.
Anyone just any answers ? Anyone know of someone with expert knowledge ?
				TheBogieMan
Is the offending plug wet or dry, if its wet then no/weak spark is the problem, if it's dry then it will be the fuelling.
If its the fuelling check the fuel lines for kinks, if you can get it off the injector and see if it squirts then it will be the injector.
If it is the injector then get a can of hairy arsehole carb cleaner and give it a good squirting, that should clear off any of the toffee that apears after a while, you should be able to hear the injector solenoid click when you put 12v accross the terminals (off the bike or you might fry the brain)
- Davy Doherty
- paul doran
- big green bus
				linus918
Thanks all for the posts. #### computer didnt let me know you lot had been replying.   Encouraging that its hopefully a simple solution and lets hope not expensive. Will have a look once again at injectors - swap them over and hopefully confuse the old girl !  As for carbs - I could have done that well over a year ago. It will have to be the last resort. might just have to palm it on to collector who likes riding for 5 miles and then spends the rest of the time polishing and looking at it !!!
				TheBogieMan
- big green bus
				linus918
