Leak-Down Test ~ How Do I Do It?
Garn 1
#1 PostAuthor: Garn 1 » Fri Aug 26, 2011 10:20 pm
I just read Z1000Pudin's "Low Compression" Topic. He mentions some good info found from a leak-Down Test.
I've never done one of these Leak-Down test.
Can anyone tell me how it is done and what equipment I need? ... I guess I need a compressor.
PS... I did a search of Leak-down Test .. I found a lot of leaks!
Leaking Carbs, Leaking cylinders, Leaking Brakes and leaking sumps along with general oil leaks!.
z1000puddin
#2 PostAuthor: z1000puddin » Fri Aug 26, 2011 10:29 pm
Garn,
Check out this link to wikipedia,very good explanation with picture set up
http://en.wikipedia.org/wiki/Leak-down_tester
stu
Zed til Dead
#3 PostAuthor: PAULJAC47 » Fri Aug 26, 2011 10:34 pm
I made one up using an old spark plug with an adaptor brazed on for my push on conector to my compressor,an in line pressure gauge is a good idea though some compressors have an in built one,good tool to tell where leakage is occuring..
http://www.bmw2002faq.com/content/view/78/32/
Check this out Cocka
