LED idiot light and clock bulbs
Mark Tiller
#1 PostAuthor: Mark Tiller » Thu Aug 04, 2011 10:33 am
Anyone know if these are available? i see wemoto do the filament type but is a LED equivalent
#2 PostAuthor: Ginger Bear » Thu Aug 04, 2011 2:07 pm
Mark, I am a lover of led lights, but I bought some to replace the idiot light bulbs on my modded Zed & they were shite, the different shade of white just didn't work behind the coloured lenses.
# 104
Taffus
#3 PostAuthor: Taffus » Thu Aug 04, 2011 2:36 pm
The company I work for has invested millions of Yen trying to achieve the "pure white" LED. to get the idiot lights looking right you need to use the nearest colour e.g. red for red, blue for blue etc.
white led behind a red lens will look pink....suits you sir, suits you :D
(\__/)
(")_(")Image
Mark Tiller
#4 PostAuthor: Mark Tiller » Thu Aug 04, 2011 4:13 pm
Thanks both for the advice....i found some on good ol fleabay
http://www.ebay.co.uk/itm/1x-BLUE-Wide- ... 588ce89c3d
gone for the different colour option...ill report back when i have tried them with a couple of photos
Mark Tiller
#5 PostAuthor: Mark Tiller » Wed Aug 10, 2011 5:45 pm
these 2 photos are with normal filament bulbs
these 2 are with colour LED BA9S fitted...the light is not difused as filament bulbs and the brake idiot light is constantly on and just gets brighter when u pull the brake? but the colour is fine
these are wth white LEDs fitted... with white LEDs fitted the colours look a bit wishy washy and the neutral looks more like light blue, in the last photo the brake light is back to a filment
Mark Tiller
#6 PostAuthor: Mark Tiller » Wed Aug 10, 2011 7:42 pm
to difuse the light a bit i rubbed the plastic glass part with fine wet and dry untill it was opaque and they now look the biz.
www.aceparts.com
nanno
#7 PostAuthor: nanno » Thu Aug 11, 2011 7:45 am
The brake idiot light is always on, because it relies on the resistance of the bulb, to trigger off the light. Same goes for the pilot-light, which will also be lit, if you trigger the brake-light.
Cheapest way to solve: fit a normal warning light bulb or add a resistor.
Greg
Mark Tiller
#8 PostAuthor: Mark Tiller » Thu Aug 11, 2011 8:24 am
Cheers nano...where would the resistor go? and what value would it need to be? i have put a regular bulb back in that one so it works as it should
nanno
#9 PostAuthor: nanno » Thu Aug 11, 2011 10:00 am
Hmm... the resistor would go in in parallel to the LED-BULB. So you could just solder one in a homegrown LED (that's what I did).
Greg
Mark Tiller
#10 PostAuthor: Mark Tiller » Sat Aug 20, 2011 1:26 pm
The company who supplied the LEDs gave me free a 47 Ohm resistor and a wiring diag which shows it in parralel with the bulb (Across), all works fine now, including the brake failure if anyone else is going to do the same
