well i think iv found my rattly engine problem.......... stuck tensioner !! not really a huge suprise after being un-used for 16 years
whilst its apart i thought id see if the cct off my old zrx11 engine would fit as its a more compact, ratchet type jobbie - it bolted straight on and took up the tension perfectly!!
i know this is a common mod on the z1300's (well, a zzr11 cct but its the same thing) but has anyone used one in a gpz motor ??
cant see why it wont work... but as id rather not end up with bent valves i thought id ask of you guys opinions
thanks folks
