Hi Guys
Do the studs that hold clocks to yokes come out of clock mount, as one of mine is bent. thanks Neil
z1000 clock bolts
clock bracket
frade not ! i have a clock bracket if you need one !
clocks stud
ar well i stand my post !
Cut it off flush with the bracket, drill, tap and then make a stud up the right size to fit and locktite it in.
Alternatively put the bracket in some water so the stud sticks out, heat the stud and bend it straight.
Personally I would take DDZ900 up on his offer.
