The clutch on my 955i sounds like it's similar in design.
On the Triumph it's possible to fit the clutch cover with the operating arm in the wrong position. It looks correct, but when you operate the clutch lever it doesn't disengage the clutch.
Sounds very similar to your problem so might be worth a second look ?
Clutch
Crofty wrote:So bearings on output shaft replaced, do they spin OK? Clutch might be fine and its the shafts in the g/box causing a problem?? Just a thought
Looked at that crofty, shaft drive rotates ok, took swing arm off took the shaft drive shaft out bearing turns smoothly no snatching or anything.
CAT3 wrote:The clutch on my 955i sounds like it's similar in design.
Ok definetly wprth a look tried everything else
Good Mikey, glad its decided to start working (a bit), last thoughts are wonder if the basket dried out, no oil to let plates slide plus a bit of wear on the fingers making the whole lot jam up. If so it should loosen up a bit with use, but really baffling. Tried to find an emoticon with a head scratch, but can't.
Crofty wrote:Was just reading an article and it mentioned clutches sticking with certain types of oil, was that changed Mikey?
It was obviously changed during the engine re build but not in this episode with the clutch strange one though never ever had this grief with a clutch
