not sure of the real history of the bike as it was built as a chop several years ago
mikey wrote:Cheers guys in the second pic does it look like there is a cover
missing off the acceletator pump, if so would this effect the running
of the bike, also the mixture screws have been turned all the way in
im guessing that is not right and they should be 1 to 1 and quater turns out?
Alexander wrote:mikey wrote:Cheers guys in the second pic does it look like there is a cover
Hi Mikey,
my mate had a set of these on his 1000- I believe were mainly used on US bikes due to emission controls enabling bike to run lean but with a handfull of throttle the pump squirted a bit gas in to prevent lag.
These carbs realy should to be used with vacume fuel tap with priming facility.
I also remember his looking like yours as if a component was missing on the bottom so maybe this is normal, but one of the online parts finders should be able to identify this for you.
The air screws being set fully in may be an indication there was an air leak in the system when they were last used. I tend to check this at tune up time by turning them fully in the respective cylinder should cut out, I found that all four carb rubbers were leaking as engine ticked over better when they were all screwed in, and after wasting time trying to seal them with RTV etc finally sorted the problem with new rubbers.
