rev counter blank off
brian 450
#1 PostAuthor: brian 450 » Sun Jan 17, 2010 9:16 pm
I am having a bit of a problem getting the bit that the rev counter cable screws to off the engine, I have removed the philips scerew that holds the plate that stops it undoing its self but when i put a 20mm socket on to undo it hardly moves and is so tight i am worried about it braking of in the engine :roll: :roll: am i doing it wrong???
tlc
International Rep
#2 PostAuthor: tlc » Sun Jan 17, 2010 9:25 pm
It doesn`t unscrew Brian. It just pulls out and has an o ring.
Suggest gallons of WD and patience.
Asphalt Cowboy
brian 450
#3 PostAuthor: brian 450 » Sun Jan 17, 2010 9:49 pm
Thanks Chris.
