z650 z900 parts interchangeabilty anyone add to this???
#1 PostAuthor: PAULJAC47 » Wed Jan 06, 2010 5:56 pm
The z650 and z750 motors are basically exactly the same bottom ends z650's have kick-starters, z750's don't. You can fit a set of z750 pistons and cylinder onto a z650 bottom end, for a cheap conversion to a 750. Heads are interchangeable. Fitting a 650 head onto a 750 bottom end will give you a slight increase in compression as well - always a good thing ;) . z650 and z750 motors can be swapped between 650 and 750 frames.
You can even fit 750 Zephyr bits to the early motors, they use the same bottom-end, lots of castings and just dress the outside up a bit.
You *cannot* fit an early Z900 / Z1000 motor into the z650/z750 frame. You can however fit the later GpZ1100 or Z1000J motors into the smaller frames. The reason is that the early 900s and thou's had the kickstart casting at the rear of the cases, the later 1000's and 1100's don't, and thus can be squeezed into a 650 or 750 frame. Its a tight fit - I just did a Z1000J motor into a 1980 z750 frame for a Period 5 racer I am currently building. Its a really tight fit, but it can be done. You need to take the cams out to fit the head on, then put the cams in and keep going ! :shock:
Most of the early 650's, 900's and 1000's use 36mm forks. These can be swapped between models pretty freely. z650 or z750 triple clamps will fit into z900 or z1000 frames, and give you much quicker steering due to the reduced offset. I have used z650 triple clamps in the Black Pearl now for 10-12 years ?? can't really remember when they went in.
Brakes - the early 900's used 6-bolt disc rotors, from the 1976 Z900A4, they went to a 4-bolt pattern. z650's also used a 4-bolt pattern, so disc rotors can be swapped freely between all models that use the 4-bolt rotor. All 4-bolt disc rotors are 295mm diameter, so no worries changing between models. The early 6-bolt rotor is the same as a H2750, as is the early-model calipers. Calipers from the 1976 900 can be freely swapped between most 1000's up to 1980. Rear brake drums / hubs can be freely swapped between H2 and early 900's with a drum brake rear. You will need to change some small items, axle spacers etc, but this is pretty easy.
From the Z1000J onwards, different calipers were used - GpZ1100 calipers can be freely swapped with J calipers from 1981 to about 1983.....the parts interchangability started to decline in the early to mid 80s, there are a lot of external cosmetic stuff that can be changed, eg GpZ1100B1 and B2 and Z1000J tanks are the same, but from 1983 onwards, the models became a lot more *specific* to themselves, in a lot of respects. During the 70's, it was another story altogether !
The twin-disc setup can be done on every Z900. They all came with a set of mounting lugs on the lower RH fork leg, and the RH side of the front hub is already drilled. Getting a disc rotor is easy, but getting a RH caliper for an early Z900 will cost you an arm and a leg. Stick a set of Z1000A1 (1977) forks on an early 900 if you want a twin-disc set-up, its way cheaper.
Wire-spoke wheels - these are freely interchangeable between all spoked model Z900's and Z1000's. The spoked front wheel of a Z650 is also exactly the same as the z900 spoke wheel. The 650 rear wheel cannot be interchanged, the rear drum and hub is smaller than the 900/1000.
Stay away from the Z1000ST - shaft drive model. *Nothing* on these models will interchange with anything else, apart from the barrel/head to other Z1000's. Everything else is different, wheels, brakes, forks, everything.
Found this on another site can anyone add to this ?could be a good resource with the good availabilty of z650 bits.....Paul J..
paulmceleney
Chunks
#2 PostAuthor: paulmceleney » Wed Jan 06, 2010 7:41 pm
I had a z650 b1 when i was 19, rear sprocket of a k h 500 fits put one on mine did make a big difference
Re: z650 z900 parts interchangeabilty anyone add to this???
#3 PostAuthor: chrisNI » Thu Jan 07, 2010 12:38 am
PAULJAC47 wrote:You *cannot* fit an early Z900 / Z1000 motor into the z650/z750 frame.
Unless you're very determined...
#4 PostAuthor: PAULJAC47 » Thu Jan 07, 2010 4:42 pm
Looks Great
v70z650
#5 PostAuthor: v70z650 » Thu Jan 07, 2010 5:01 pm
Thanks Paul - that is a great source of advise and very timely as I'm hacking around the front end of my z650 at the moment.
I'm actually fitting a GPz750 wheel into the standard z650 forks. I found out that a the z1000j and equivalent z750 (and possibly late z650s too) that use the 7 bolt disk have a similar hub to the GPz and therefore have the correct spindle (15mm dia rather than 17mm) with older style hex end caps of the correct dia to match the wheel into the forks. I now just need to figure out what brake calliper hangers I need to get the offset right etc and I will be away.
Rob
p.s. If anyone has a front wheel spindle from a z1000j or similar that they don't need (?) then please get in touch.
- v70z650: [Gallery] [Project Page] -
Rob Lafferty
#6 PostAuthor: Rob Lafferty » Thu Jan 07, 2010 5:11 pm
Don't like to throw a spanner in the works ove disk sizes, but there are different sizes out there. I have a z1000a1 which came with a standard single disk setup, so decided to convert to twin discs. Purchased a second disc and it is about 4-5mm difference in size. Standard orignal disc is 297mm.
Does anybody know if there are different size discs or are the differences down to manufacturing tollerences ? ( I suspect not)
Rob
zedrider
#7 PostAuthor: zedrider » Fri Jan 08, 2010 7:59 pm
from memmory i think i remember working on a z750 the cam timeing was done on the end not in the middle much like a gpz . ? the very last of the z650 engines were developed for the gpzs
zed
