I need to get my master cylinder refinished, ideally black powdercoat. No problem normally, but this is the m/c with the little round window for keeping an eye on the fluid level. The guys that powdercoated the rest of my stuff, thought it might be a problem when heated up (200 degrees) in the oven they use.
Anyone out there had their m/c of this type powdercoated? Can you get hold of the little window seperate, like you can with the engine oil windows that go in the clutch covers, if it goes tits up?
I guess I could respray it and try to match the finish if a problem. Cheers, Jim
Powdercoating a master cylinder question.
- coldsummer
coldsummer wrote:Crofty there are probably better options than powder coating. Mikey might have some advice ref anodising....
I have anodised a few of these with good results, doing 3 at the moment for club members, only problem is steel wont survive in an anodising tank, and i believe im right in saying that the sight level glass has a steel reinforcing ring round it?
Came in from the shed as its freezing and started Googling re master cylinders and powder coating with glass windows and
http://www.newrivercyclesalvage.com/sight%20glass.html
Computers are amazing, mind you I've not contacted them yet.
Still prefer to try taking one out of an expired genuine m/c.
