Hi from windy Western Australia,
Anyone know the set up with collets on Harris 4-1 pipe. Early 80's style.The pipe is stamped Z1000,mines a Z1a.....collets from 900 too small.Does it require Z1000 collets or Harris ones?
Thanks Pete
Harris 4-1
- PETER KZ1A
Z1000/900 HEADERS
I have a Harris on my 900A4. It is stamped Z1000. The only difference I could see was the size of the holes on the clamps ie 8mm instead of 6mm. I just used a repair washer before I put the 6mm nuts on.
Jimmock
Jimmock
Jimmock.
I hate people I don't like !
Steve Cooke
My last Z1000 had a harris and I have two in the garage now and none of them use split collets, they all have a double skin at the entry to the head. Of the two I have now one has the double skin fixed and on the other the double skin will rotate and pushes up against a slightly flared end, the earlier of the two has the fixed skin.
